hikvision DVR 1080 with synology NAS
wesam_az
Postby wesam_az » Tue Feb 14, 2017 3:06 pm
I want to take a backup of my DVRs (9 Hikvision DVRs 1080) ,I'm wondering whether can I use any NAS with my DVRs!!
so if anybody has an idea about this subject can advice me..
I found so many NAS devices , WD my cloud, QNAP , seagate and Synology
also want to take your advice about this NAS (Synology Diskstation DS1515+ Series NAS - 5 Bays) ,is it good with my situation
and the last question is I 've already bought 5 HDD WD purple 4TB, to use them with the NAS , is there any problem if I use these HDD with the coming NAS instead of WD red???
thanks in advance
waiting your reply
Re: hikvision DVR 1080 with synology NAS
Postby adam » Fri Feb 24, 2017 2:35 pm
I would have thought the purples will be OK for light NAS use.
In terms of using such a device, you will have to check with Synology etc on their propper software. But if it is just NAS space then if you go to storage > NET HDD you can setup a NAS disk there...
Users browsing this forum: Google [Bot] and 1 guest
