Issues with the web plugin and the latest Firefox Browser version(52) and beyond - and the fix.
Post Reply
Post by adam »
So it seems as of last week Firefox released a new version (52) which pretty much breaks all browser plugins apart from Flash (which is what rendered Chrome useless for this not so long ago). This means you may keep trying to install the WebComponents plugin but it does nothing. Thankfully there is a fix:
How to use Firefox v52 to live view Hikvision device
1. Install the plug in first.
2. Open a blank page of Firefox and input about:config (where you normally type the web address)
3 Press Enter. Click on the, “I Accept the Risk” Button.
4. You will then be in the plugin section of Firefox.
Right click, then go to NEW from the dropdown list. You will have 3 options to choice from, you will need to select Boolean. Once you have done that, you will need to type the plugin name:
plugin.load_flash_only
Click OK and choose “false” for the VALUE.
5. Exit firefox and reload the DVR/NVR web interface to 'accept' to run the plugin at the top of the page (all being well).
There were a few other steps recommended past this, but we have found this alone to do the trick.
Adam
malford
Re: Issues with the web plugin and the latest Firefox Browser version(52) and beyond - and the fix.
Post by malford »
When is a permanent fix going to be applied?
Only last week I recommended a colleague purchase a cube camera only to find out after several hours fiddling with Chrome & Firefox it went into a loop asking him for the plugin to be loaded for the 6th time.
i appreciate your fix for this but is this going to be a problem in the future?
Post by adam »
From what I gather this is down to Firefox being awkward so at present something out of our control. It is the same for any web plugin whether it be for Hikvision or anything else.
If you are looking for best reliability I'd install iVMS on the PC anyway from HERE
ToeMain
Post by ToeMain »
Just wanted to say THANKS for this fix!
A little note: You can't copy-paste the "plugin.load_flash_only" line or it'll fail. You have to type it in directly.
Other than that, it worked perfectly. And it took forever to find this through Google, btw. Just happy I did. Adding a few keywords to bump up the relevance in searches.
Firefox won't work hikvision. Firefox webcomponents.exe Webcomponents hikvision firefox. Browser won't show camera.
ingeborgdot
Post by ingeborgdot »
So what acutally is iVMS anyway?
ToeMain, did you install the iVMS or use the fix adam suggested?
ToeMain
Post by ToeMain »
I installed IVMS, which is almost like the Iphone app but for windows, and when viewing camera content it was extremely slow. Way too resource intensive. The firefox fix Adam suggested worked great though!
jtwhitfield
EZVIZ Studio
Post by jtwhitfield »
I've had all the browser plugin problems, and the firefox fix that worked (about:config), but that stopped working for me today.
I was about to give up trying to reinstall it again when I happened to spot EZVIZ Studio on the Support page ( https://www.ezvizlife.com/support/support.html ) and wondered what it was.
It's a Windows application that enables remote access with no browser involved. Just log in to your account, works a treat, and will also show cams on the LAN. I've no idea how long it's been there, but it's very welcome.
Godwab
Issues with the web plugin and the latest Firefox Browser version52 and beyond and the fix
Post by Godwab »
Please help with PHP update.
I updated my site on the servers request, then nothing seemed to work. When I mention it to the service provider, they said that it because the version is to high for the server and they can not run it back. I dont know what to do. Ive been waiting for a long time.
Can somebody please help?
Thank you.
BeJimmiestedy
View first unread post
Post by BeJimmiestedy »
Why does clicking on the View First Unread icon hardly ever do just that? Sometimes it does but is mostly fairly random.
Anyone else have this problem?
Post Reply
