NVR Fan noise
Spikeymikey
NVR Fan noise
Postby Spikeymikey » Sat Feb 03, 2018 1:39 pm
Am I the only one on here converting my Hik DS7608 NVR fans to super silent 40mm Noctua's?
I've searched the forum but nothing showed up.
My old CNM DVR was fanless and quiet as a mouse but my new Hik NVR sounds like you've left an outside tap running.
I love my Hikvison but can't believe they fit such noisey fans as standard.
homer664
Re: NVR Fan noise
Postby homer664 » Fri May 17, 2019 8:16 pm
I did that to my NVR, but it barely helps since most of the noise is generated when air is flowing through the NVR case venting holes. This can be easily demostrated by removing the case cover, the NVR is almost silent then.
Re: NVR Fan noise
Postby adam » Thu May 23, 2019 10:26 pm
We did buy some silent fans from ebay, did make an improvement!
Tom
Re: NVR Fan noise
Postby Tom » Sun Jun 30, 2019 10:40 am
It depends on the unit and channels in use, for instance, if you have an 8 channel nvr and are only using 4 - clearly, your power demand on the system is half of design - so just unplug one of the fans
Users browsing this forum: Google [Bot] and 10 guests
