Smart Event Limitations on DS-7208HUHI-K1
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Bovril
Postby Bovril » Fri May 31, 2019 11:49 am
I have a DS-7208HUHI-K1 currently with 7 cameras all connected by BNC. The DVR appears to only allow 2 cameras using the Smart Event feature (line crossing, intrusion detection etc). if i try to add a 3rd I get an error message 'the camera does not support the function', if i disable one of the other 2 cameras using smart event it allows me to activate the one that gave the error, so only 2 can be active at any one time.
My question is that if I add IP cameras will I be able to use Smart Events with them or does this DVR only support them for 2 cameras in total?
